Going to Start Prepping for 37's
Old Nov 19, 2009 | 03:26 PM
So_Cal_Tay_12's Avatar
Default Going to Start Prepping for 37's
Yeah, so ive pretty much decided its time to start saving up to upgrade from my 35's.
On a 2dr X Ive currently got a teraflex 2.5" lift with 35's on stock rims and 1.5" wheel spacers. Ive already got a new tire carrier so thats not a problem
Heres what I plan to do.
-Upgrade to 5:13's front and back
-New front driveshaft
-Beef up the front Dana 30 with c-gussets and chromoly axle shafts
-The 37's (still deciding which ones
The question I have is what lift to go with. Im planning on a teraflex long arm but dont know whether to go with a 3" or 4". I like that actual height of the jeeps Ive seen running the 3" lift better but dont know if a 37 will fit without rubbing. Any input on this, or anything else I may have missed, would be greatly appreciated.
Old Nov 19, 2009 | 04:02 PM
Originally Posted by redx08
i know piginajeep is runnign 37's with his 3 inch long arm. You can run 37's with trimming, correct bump stops on a 3 inch teraflex without rubbing.
Thank you, when time comes time Ill ask him a few more questions
Old Nov 19, 2009 | 04:11 PM
AlmightyCrash's Avatar
love my 3in Black Diamond...
measures out a little over 4" in the end.
36s are no problem with trimming., 37s would be the same i think.
Old Nov 19, 2009 | 04:26 PM
what kind of trimming are we talking? I know the pinch seem but what else? I think my aftermarket sliders should clear but ill double check
Old Nov 19, 2009 | 04:28 PM
fenders, air dam if you still have it, possibly the backside of the stock bumper....the rest would depend on offset/backspacing.
Old Nov 19, 2009 | 04:34 PM
Suffolk JK's Avatar
Do you wheel the JK?
Are you going to lock the D30?
Old Nov 19, 2009 | 04:43 PM
Yes I wheel it. . .a lot, and no I wont be locking the d30
As for the trimming, good to know since Ill probably be making a new set of most of that stuff soon, Ill factor all of that into the decisions
Old Nov 19, 2009 | 04:57 PM
Suffolk JK's Avatar
Just making sure. Once you lock the D30 on 37s and 5.13...good luck.
I think you'll only need to bend the pinch seam in. At 4.5", you have ample room for 37s.
Old Nov 19, 2009 | 05:06 PM
I thought the teraflex 3" LA only gave 4 inches though, not 4.5
Old Nov 19, 2009 | 05:59 PM
joneszj's Avatar
d30 running 5.13s and 37s, might want to rethink your think. a 4.88 ratio may be less abusive, but either way, the d30 needs a lot of reinforcement to work with 37s if you plan to wheel. I'm talking gussets, inner and outer sleeves at the very least. And don't really plan on a locker at any point with 5.13s and 37s.
I plan on eventually running 37s, but not until i wear out my 35s...and get 4.88s, diff covers, C gussets, inner and outer sleeves, a Super 30 kit which upgrades the 27 spline to 30 spline, and an ARB locker... Should be good for what I do...I'm still debating whether or not I want the lockers or not
