Alignment after Wheel Spacers?
Wouldn't checking the toe be a worthless effort if the only change is wheel spacers? If the spacer is not milled correctly then the toe would be off as soon as the wheel rotates, no?
You are right, but I wasn't considering a large variance.
The Toe angle should be small to begin with and small variances will affect it.
Either way, it appears that there was a lift kit involved, so all bets are off.
There's nothing on your Jeep that you can't align yourself in just a few minutes. Don't pay anyone to do it. Now, that changes if you install adjustable track bars and control arms, etc, but even after that many folks are doing their own alignments under their favorite tree. Here's a write-up ...
Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
