Who has the cheapest adjustable front control arms?
I just bought a 3.5 krawler kit and I want to atleast fix my caster with some adjustable arms. Who has the best deals going right now?
Are there adjustable control arms I should stay away from? My understanding is that most of the aftermarket arms are considered to be stronger than the brackets they connect to.
Also what gives more adjustment to caster, front uppers or lower?
The adjustabel lower CAs give you a much wider range of adjustment (more than you will ever need) by the simple virtue of their ability to extend more than many
upper CAs can contract.
Dave's comment above is a good information to know, since some upper CAs minimum length is close stock length, therefore negating much of their value.
He points out that the Currie's UCAs (which are a quality product) are shorter than others which is good as long as they can extend enough to overcome that reduction in length.
I wish my Clayton's were about half an inch shorter.
Front lowers will give you more caster adjustment. I believe only the Currie front uppers will adjust short enough to dial in your caster. Currie, Clayton, Teraflex, JKS, Rock Krawler (and others) are all quality arms. I'd stay away from the non-adjustable arms.
I have a TeraFlex 2.5 coil lift and was able to use Clayton's uppers to adjust my caster from 2.3 degrees after the lift back to the factory setting of about 4.2degrees.
The main reason I went with their's is they are a 40 min drive from me.
Clayton and Adam felt that was the best route for me to go with my setup.
Clayton's is also running a sale on their stuffs this week.
I am in no way affiliated with them, just happy with their products and customer service.
I have these for front and rear lowers and like them very much. Much beefier than stock and the price is right compared to the bigger brand names. I never heard anything bad about Rusty's so so far so good.
