Balancing 35" MTR w.kevlar
Old Nov 24, 2009 | 01:27 PM
Default Balancing 35" MTR w.kevlar
Anyone else running these tires please comment on how much weight it took to balance the tires. I had mine done today and all the tires took around 4 ounces to balance. does this sound right?
35" tires on 16" steel wheels
Old Nov 24, 2009 | 01:38 PM
Suffolk JK's Avatar
3 of 5 took QUITE a bit of weights to balance. These were on 15s.
Old Nov 24, 2009 | 01:47 PM
Suffolk JK's Avatar
I get the strip weights that are taped to the inside of the wheel, not the bead edge. Don't care much, it works, that is all.
Old Nov 24, 2009 | 01:58 PM
phljeeper's Avatar
It took quite a bit of weight to balance mine on stock Moab wheels. Not sure how much, but weights on both sides of the wheel.
Old Nov 24, 2009 | 03:44 PM
ifshinxs's Avatar
I just had my 33's mounted on stock wheels.
It took from 4oz to 7 oz to balance the tires..That weight is the combined weight front and back.. Had I mounted these myself I may have spun the tires 180 on the rims just to see if the weight would come down.
With 35's and steel wheels the weight could get up to 10oz combined..
If it takes this much weight, spin the tires 180 degrees on the wheel and try again.
I like doing the static balancing also with the weight taped in the center of the wheel...With 15" wheels you might bet a rub on the caliper.
If yours only took 4 oz combined...You done good.
Old Nov 24, 2009 | 03:56 PM
Ryanc's Avatar
Mine took quite a bit of weight, they were not easy to balance. Had to go back, to get them rebalance.
Old Nov 24, 2009 | 04:26 PM
nangulator's Avatar
Last week I put a set of 32x11.5x15s on a customers tj and I got 4 of them to balance under 3 ounces ( I had to spin 2 of them on the rim a few times), but the 5th one took 6 ounces no matter where I moved the tire on the wheel, I put it as the spare.
Old Nov 24, 2009 | 04:53 PM
GoodysGotaCuda's Avatar
Originally Posted by rickc309
You guys getting them Road Force Ballanced? It can reduce the weights needed.
Many places do not force match tires without asking/paying more. It can reduce the amount of weight, it does take time..time is of course money.
Old Nov 24, 2009 | 05:48 PM
Suffolk JK's Avatar
With 15s and taped weight, no rubbing on calipers. He wanted to stack the weights, but then it rubbed. Rotated 180*, good to go.
Old Nov 24, 2009 | 06:09 PM
0311sgt's Avatar
8 oz of internal balancing per tire. for 3 reasons
1 no lead in the environment for tree huggers to bitch about when we throw a weight on the trail
2 when aired down eventually you will spin a wheel inside the tire unbalancing it. internals will automaticall re-balance
3 looks better.. no weights on the inside,outside of rim. Or stacking issues rubbing on calipers for the 15inch guys
2007 JK Unlimited 6 Speed 4.10 Gears
3 Inch BDS Lift
35x12.5x16 Yokohama Geolander AT/S
16x8 Cragar Soft 8 Black Steel Wheels
Custom front Winch Bumper from RoundStar OffRoad
Mopar Offroad Rear Bumper
Oilpan/Tranny skid Plate by Skid Row
JKS Quicker Disconnects
Skyjacker Brake line extenders
Skyjacker Adj Rear track bar
High Clearance Adj Front Lower Control Arms by RocKrawler
RocKrawler Front Lower Control Arm Mounting Bracket/Skid Plates
Warrior Products Rear Safari Doors
Plenty of ROCKRASH
