Need help/Advice in 15" rims.Pro-comp
Im placing my order for some rims/tires and i would really like a set of either of these cheap rims.Tires will be Interco Trxus 37x12.50
Pro Comp "Steel" wheels 15x10, 5 on 5 Bolt Pattern Bolt Pattern:
Rock Crawler Series 98 Black Steel Wheel 3.75 bs
or
Pro Comp Xtreme Alloy 15x10, 5 on 5 Bolt Pattern Bolt Pattern: 5 on 5Diameter: 15.00 "Width: 10.00 "Style: 69 SeriesFinish: Black Construction: Aluminum Backspace: 3.62 "Max Load: 2200 lbsHubcentric: No Offset: -46 mm
Can anyone verify that they will fit without any issues,Ive searched and read everypost on here but havent seen hardly any info on these.Pictures would be great. Thanks
or
I seen it.Ive searched and read every thread on 15" rims but nothing seems to show these rims.Its kinda wierd because they are on 4wheelparts website and are nothing more then black steel rims that are dirt cheap.
Just wanna be alittle more sure about them fittin before i order in the morning.thanks
Have the shop order them in, and test fit all of them. --- on all four corners!
Guess ill be going with 16" then. I was wanting to get them with the sensors already installed so i wouldnt have to bust up a set of rims/tires i have and take them out but ill just drop them off the price $$240 and move up to 16".
Do yall know if the sensors can be installed without taking the tires off the rims?Just let all the air out and push it down. THanks
Thanks yall for the help.Im going to order this setup.
37x12.50 interxo trxus mt
Pro-Comp 15x10 series 98 rims 3.75 backspacing
Just cant make up my mind but im going the cheap route so i can buy more stuff
I just bought (1) Pro Comp "Steel" wheel 15x8, 5 on 5 Bolt Pattern Bolt Pattern: Rock Crawler Series 98 Black Steel Wheel 3.75 bs except they sent me a series "97" wheel to see how it fit.........guess what.......scrape scrape scrape. I'd like to know if the "98" series are any better. The new 4WD.com catalog says they will fit an 07-09 JK. I'm trying to find out why I was sent the wrong wheel in the first place. You may have issues also with a Rubi.
give it a week and ill see if i have any problems with the 15x10's. I ordered them and some 37x12.50's with an xrc rear tire carrier,Now im broke again but who cares
