TF 2.5" BB vs coil lift
Old Nov 26, 2009 | 07:11 PM
mattyhfd's Avatar
Default TF 2.5" BB vs coil lift
so i thought i was set on getting the coil lift by tf until i spoke with someone who said that bc the coil lift is a 3.25" in the front that the likely hood of messin up my rear driveshaft is more likely. anyone else hav an opinion on this?? and pics of both the BB(which ill b getting if i dont get the coil lift) or the coil lift
Old Nov 26, 2009 | 08:16 PM
I have the tf 2.5 coil and the guy that owned the shop that did mine told me even with a 2.5 lift, the rear driveshaft will eventually go out. It may be 30000 miles and a few years down the road, but it will eventually fail because of the increased angle. I have about 13000 miles on mine and I have not had any problems yet. I just keep some $$ back incase it decides its job is done. (if it ain't broke, don't fix it) I'm still pretty new to all of this so I'm sure someone with more knowledge may be able to more accurately answer your question.
Old Nov 26, 2009 | 08:23 PM
Here's a pic of my tf 2.5 coil
Old Nov 26, 2009 | 08:44 PM
07Rubi2dr's Avatar
your rear drive shaft will be fine many people including myself have run it for quite a while with no issues. I have even been running after adding coil spacers to my 2.5"coils so i'm almost at 3.5-4" lift and still no driveshaft issues.
they are supposed to become a problem after about 3-3.5" of lift so now I have set aside money for when mine goes...but you will be fine for a good long while before a driveshaft goes on a 2.5" lift
