Toyo Open Country or Nitto Muds, need some help
Old Nov 28, 2009 | 12:55 PM
krackle959's Avatar
Default Toyo Open Country or Nitto Muds, need some help
Ok, so this is my first post for help with my JK. I have been reading and learning all about a lot of things on this site, there is great info here. I bought a 2010 JK Unlimited 3 weeks ago, and have already ordered a RK 3.5" X Factor, Fox shocks, a Flashpaq, new 4.88 gears with a Arb Locker, and a set of Xenon 1.5" wider flares.
In Maine they are strict about tires sticking out beyond the flares, and anything beyond is a $150 fine. The only thing left are tires, I am leaning towards the Nitto Muds, in the 35x12.5x17 flavor, or a set of Toyo Open Countrys in the same size. The tires will be mounted on 17x9 rims with a 4.5" back spacing. I am leaning towards the Nittos, but am worried even with the flares they will stick out beyond them. The sidewall can be beyond but not the tread, I know there are a ton of jeeps on here with both tires. Can someone help me out and let me know how much beyond stock flares these tires stick out, or the Xenon's. I have searched but haven't seen too many pics that clearly show what I am looking for.
I am hoping to order the rims and tires on Monday, so next weekend will be the big wrenchathon at the shop. If you think I might be missing anything else from my list, please advise me as to what I might need. Any pics or info in the right direction is greatly appreciated, and thank you in advance.
Old Nov 28, 2009 | 12:59 PM
JonP's Avatar
I'm running 33x12.5 Toyo's
They seem to be great tires, 7k miles on em. Mine do stick out approximately 1/2 - 1 inch past the stock fenders. I unfortunately don't remember my back spacing. although I don't rub, except into the fender under full flex.
Hope this helps a little.
Old Nov 28, 2009 | 07:03 PM
w squared's Avatar
If you want a tire that looks b@d@ss, then get the Nittos.
If you want a beefy tire that will perform well on varied terrain and still have reasonable street manners - and also soak up a HUGE amount of abuse without complaint, but the Toyos.
Old Nov 29, 2009 | 09:53 AM
nwjk's Avatar
The Toyo's and Nitto's are the same actual dimensions.
Toyo's are much better on the street.
