JKS Coil Spacers
Old Dec 1, 2009 | 01:51 PM
Ainokea
Guest
Posts: n/a
Default JKS Coil Spacers
Does anyone have first hand knowledge of these spacers?
Old Dec 1, 2009 | 01:56 PM
Northridge4x4's Avatar
Sponsoring Vendor
ACOS?
Yes they work really good. Have a specific question about them?
David
Old Dec 1, 2009 | 02:09 PM
Ainokea
Guest
Posts: n/a
Yea, what's the maximum lift height from them and will it clear 35's?
Also, are there any other mods that this kit requires? I've seen the specs but wondering what approximate height the kit was designed for?
I've been through all the mental gymnastics regarding 2" vs 3.5 and up... LCA, driveshafts... will probably add bilstien 5100's if they can be used now and later for 3.5 lift.
Old Dec 1, 2009 | 03:04 PM
spinlock's Avatar
The rear spacers have a different range than the fronts.
I am seriously considering a set of front ones when I start adding weight to the front with the usual paraphanelia since I have a strong distaste for rake, and I am not sure that AEV will sell me a just a set of 4.5" springs to eliminate the sag.
The front ACOMs can provide 1-31/2" lift.
I know two guys who use them and they have had no issues. This is not a surprise to me because JKS has great engineering and manufacturing.
You can probably get a larger sampling if you create a poll question.
I believe the rears provide between 1.5"or 2" and up to 4" of lift.
If you set them to 2.5-3" you should be able to clear 35s just fine and also eliminate much of the rake if you want.
Old Dec 1, 2009 | 03:05 PM
spinlock's Avatar
I meant front ACOS
Old Dec 1, 2009 | 03:19 PM
dream catcher's Avatar
They work well, I have them on my 07 unlimited.
Old Dec 1, 2009 | 03:59 PM
seer1's Avatar
They're adjustable and expensive. They give you the ability to precisely set your lift heighth at each wheel. If you're just looking at BB vs spring lifts there are cheaper (and just as effective) ways of raising the JK. If you're thinking of ACOS and stock springs... I don't know if the OEM springs are all the stout once you start adding stuff.
I'm running ACOS f-r on top of the AEV 3.5" BTW.
Old Dec 1, 2009 | 04:44 PM
gfe jeep's Avatar
Default ACOS for JK ?
I saw on Northridge 4x4 some for a TJ.
Are they available for JK?
Old Dec 1, 2009 | 05:41 PM
spinlock's Avatar
The ever popular BBs use the stock springs, so I don't think the springs will be a glaring issue.
Are you running both front and back?
How much lift do you have dialed in the ACOS?
Front:
http://www.northridge4x4.com/proddet...?prod=JKS-2210
Rear:
http://www.northridge4x4.com/proddet...?prod=JKS-2570
Old Dec 2, 2009 | 05:37 AM
webekd's Avatar
Used them to take the rake out of mine. I think the JK's even with the BDS 6.5" still rakes to the front so cranked them up 1/2".
