33x13.5 r17 tire on a stock r17 x 7.5inch wide
Old Dec 2, 2009 | 07:30 PM
MUDNINJA's Avatar
Default 33x13.5 r17 tire on a stock r17 x 7.5inch wide
i know the 33 x 13.5 are recomended for 10 inch wide rim but has anyone put these size tires on a stock rubi rim?
Old Dec 3, 2009 | 12:13 AM
spinlock's Avatar
The recommended rim width depends on the specific tire. Ten inches is not the standard and it is actually on far end of the range.
Many 12.5 tires recommend a 8.0-8.5"+ width range, but many of us get away with the stock wheel width of 7.5".
Mounting a 13.5" tire on a 7.5" rim, IMO is pushing your luck, specially when you are only using a 33" tall tire.
The taller the sidewalls the more ability they have to bulge out to accommodate the narrow rim, which is OK up to a certain point.
That sidewall bulging will create additional heating of the tire and require additional clearance on the face of the fender well.
A short sidewall will force the tread to bulge, which will automatically lead to poor handling and accelerated wear.
There are a number of threads regarding this issue, since many of us like the stock wheels or prefer to upgrade the wheels later.
Old Dec 3, 2009 | 03:56 AM
ifshinxs's Avatar
They will fit...Its just not a good idea. The 7.5 wheel is just to narrow for a 13.5 wide tire. You'll be pinching the bead which will cause the center of your tire to bulge..Aired down you'll have excessive stress on the side walls..
IMHO a 9 inch would be the minimum with that wide of a tire..
Find yourself a 33 inch tire with an 11 inch width and your good to go.
Old Dec 3, 2009 | 04:29 AM
phljeeper's Avatar
x2, what are you looking to gain with the 13.5 wide tire? The 12.5 fits great on the stock moab 17" wheels and is much wider than stock. A 13.5 would end up sticking way out beyond the flares and in my opinion look way too wide for a 33.
Old Dec 3, 2009 | 04:37 AM
MUDNINJA's Avatar
thamks for your help , it cause i found and set of iroks for a 100 dollars and really want them on my truck, either way im gonna try them on, im not sure if ill need spacers or not
Old Jan 29, 2010 | 02:00 PM
rroberto's Avatar
keep us informed of how it fits please!!! i had the same question
