Teraflex 2.5 Spring + Xenon = What Max Tire Size
Old Dec 4, 2009 | 08:14 AM
Default Teraflex 2.5 Spring + Xenon = What Max Tire Size
Hey all. I now the 2.5 spring lift from tera says it will take a 35 tire. I was wondering if I can get away with a 37 since I have xenons. If not does anyone know what springs I would have to buy to get it to work? I want to stay as alow as possible but have 37s
Old Dec 4, 2009 | 08:18 AM
sully151's Avatar
You could probably get away with some Tereflex 3" springs ad be fine. Maybe just the rears.
Old Dec 4, 2009 | 09:55 AM
JK Rocker's Avatar
You have a bumper and winch, so if you have a 4 door, I'd recommend you get 3" springs for the front and 2.5" for the rear.
I had the 2.5" BB, and my winch brought the front down way too far. I now have 3" springs up front and the 2.5" spacers in rear.
I think that with the right bumpstops to prevent stuffing too far into your fender, you might be able run 37's with 2.5" lift.
Old Dec 4, 2009 | 04:04 PM
cyruspura's Avatar
You should be good with 37" tires provided you have wheels with the proper backspacing. Trimming the pinch seam/ rubicon rock rails might be necessary, and it might still rub.
Old Dec 4, 2009 | 04:09 PM
Suffolk JK's Avatar
Xenon flares are like chopping the stock flares, IMO, on a TF 2.5, 35s max under full articulation. I have the TF BB + a 3/4" puck in the front, 3.25" total. Running on 35" MT/R Kevlars, I only have like 1" before it rubs the flare. You'll definitel rub with 37s.
If you want 37s, you'll need a body lift with the TF 2.5, try the setup that Planman has, it works.
Old Dec 4, 2009 | 07:17 PM
6DoF's Avatar
2.5" and Xenon flares will clean 38's awesome. put in the right bump stops and you won't rub anything.
i have 35's and they are dwarfed, wish i had 37s. flexed the chit out of her the other weekend and touched nothing at all thought, was sweet.
Old Dec 4, 2009 | 07:44 PM
style_front's Avatar
Let me preface my post with the fact that I have not personally done this.
That being said from every thing that I have read I would not hesitate to run a 2.5 lift and 37's as long as you hacked your fenders. Just get longer bumpstops.
