Jet Chip AND Superchips-AEV ProCal
Is there anything wrong if I have the Jet chip installed and I try to use the superchip or the AEV ProCal in order to adjust the computer parameters?? Or should I remove the Jet Chip?
I (as well as a few others) use the Flashpaq and the Procal on a regular basis, which is a *similar* situation, with no problems.
I run the Flashpaq first and the load set each parameter individually with the Procal.
You can run a very simple test by doing the same thing.
Install the Jet Chip first then set one parameter at a time the the Procal. If you want to play it safe, drive it for a day or two before Procal you set another parameter.
IMO, the only that *might* be an issue is the tire size because it can impact other things, but if I had the Jet Chip I would certainly try it.
Specially because it is so easy to reset back to stock with the Procal.
OR, you could trade in your Jet Chip for a SUPERChips.
So in a few words...
Jet Chip + Superchips = Bad Combination?
I was thinking if I use the Superchips and Jet Chip is like f I disable the Jet Chip, am I right?
If so I need to sell my Jet Chip
SUPER crazy thread revival...but.....how'd this go? I already have a Jet Stage 1, don't really need the Superchips or Hypertech, did the Procal work OK with the Jet?
