weird noise - spacers?
Old Dec 22, 2009 | 08:35 PM
IcyFridge's Avatar
Default weird noise - spacers?
I have a weird rattle or metallic noise coming from my Jeep when I hit dips or cracks in the road. Is it the suspension "slapping"?
I am paranoid it is my wheel spacers or something? I went over a washboard road and not a sound. I went over a speed bump and not a sound. On cracked pavement in my parking lot it rattles as my wheels go over them...
I checked torque on outer lugs and they are good. Can't pull off the wheels since I have no garage. But rocking the jeep back and forth doesn't produce a sound. I tried to jiggle my exhaust tip as hard as I could and there wasn't a sound. Nothing loose in engine. I do have some loose hard stuff in my center console and I can hear it when I turn, but it shouldn't make a noise when going over a small bump?
Any thoughts? Maybe I'm not used to having a Jeep, since I am coming from a WRX. I'm deaf so I can't pinpoint where the sound is coming from...
Old Dec 22, 2009 | 08:39 PM
GoodysGotaCuda's Avatar
are those all the mods listed in your sig? any sway bar disconnects ?
Old Dec 22, 2009 | 08:43 PM
IcyFridge's Avatar
The only mods not installed are the flowmaster and IPF lights, since they haven't arrived. I am running with a straight pipe out the back from the stock exit behind the axle. It's held in there good.
What you see in the sig is what I got. No disco's.
Old Dec 22, 2009 | 08:45 PM
You did remove the rotor clips before installing the spacers didn't you? I'm wondering if there is a lug nut rattling around in there (not sure if that's do able). But go to a parking lot and take the wheel off if you have to. It's certainly worth if if a spacer is walking loose.
Old Dec 22, 2009 | 08:52 PM
IcyFridge's Avatar
The rotor clips have been removed (the things around the stock lugs?).
And all the lugs were tightened the same as the outer lugs with loctite. I couldn't figure out how to use the torque wrench so I tightened them the same way I would tighten my wheels up, which is pretty damn tight.
Old Dec 22, 2009 | 08:53 PM
IcyFridge's Avatar
The thing is... going over washboard roads and speed bumps isnt producing the sound. Only when going over small cracks or sharp angles (fast suspension compression/rebound).
I am going to check my radar detector to make sure that it isn't the problem. Also. I will go now and make a short video and upload it to mediafire, where you guys can click and download it.
Old Dec 22, 2009 | 09:12 PM
IcyFridge's Avatar
here's the video. I took a relatively flat road and then made a left turn and went over a speed hump real quick. Then for the last few seconds you can hear all the rattling while I go over the cracks in the parking lot. console and glove compartment has been emptied, radar detector removed, etc...
http://www.mediafire.com/?nnmywfj2ytj
Old Dec 23, 2009 | 08:53 AM
IcyFridge's Avatar
Anyone? I should be home for xmas day, I will pull off my wheels and check the spacers. But anyone have an idea what this could be?
Old Dec 23, 2009 | 09:01 AM
jk20084p's Avatar
I didn't see your video, but from what you describe, it seems more like something loose in the drive line / suspension... I would simply have it checked by a mechanic in any garage...
Old Dec 23, 2009 | 09:03 AM
pkess3's Avatar
I had a similar noise after I installed my spacers but it turned out to be the bushing on my Full-traction adjustable track bar needed more grease and tightening. I've been running them now for almost two years with no issues.
