Okay so who is feeding me a line of bs?
Old Dec 23, 2009 | 12:24 PM
Hellbound13's Avatar
Default Okay so who is feeding me a line of bs?
I was under the impression that you could not use shocks for a lift with a non lifted Jeep.
Well after talking to both Skyjacker and Old Man Emu, both claim the shocks they sell for a 2 inch lift will work fine and without issue on a stock suspension.
Does this sound wrong to anyone else?
Old Dec 23, 2009 | 12:28 PM
Cpt. Flapjack's Avatar
It all depends on the compressed length of the shock. If it is short enough that the axle hits the bumpstops befor the shock completly compresses, then it is ok. I believe the regular, not LT, OME shocks have the same compressed length as the stock shocks.
wayoflife's Avatar
JK-Forum Founder
can't speak for skyjacker but the standard OME shocks are factroy length and those will work just fine up to 2" of lift. the OME LT shocks are a different story as they are "long travel" and thus, too long.
Old Dec 23, 2009 | 12:33 PM
goldtr8's Avatar
If the shock gets too long your springs will fall out. Thats why you need longer shocks for longer springs.
Old Dec 23, 2009 | 12:35 PM
Thanks for clarifying guys. I was afraid I was just being told what I wanted to hear.
That clears it up.
Old Dec 23, 2009 | 01:04 PM
OoPEZoO's Avatar
So whats the deal with the OME LT Vs the standard OME shocks? Do they compress shorter, extend further, or both compared to the standard shocks?
Old Dec 23, 2009 | 01:16 PM
wayoflife's Avatar
JK-Forum Founder
they are long travel shocks meaning that they have a longer shock shaft. this will give you more droop but in order to accomodate them, you will need more lift as well as without it, you would bottom out your shocks.
Old Dec 23, 2009 | 01:38 PM
spinlock's Avatar
All shocks have a range of lift they can support.
That range is usually 2-3" for shorter shocks (closer to stock) or 3-4" for longer travel shocks.
If you are near the boundary of either range you can go with either shock. This allows you to have more as less drop as WOL described.
Old Dec 23, 2009 | 01:42 PM
mkjeep's Avatar
Be sure to get the right color shock or you will get death wobble.
Old Dec 23, 2009 | 01:43 PM
I heard the polka dot ones are good for DW, I think they are those new Louis Vitton nitros.
