Steering Question???
Old Dec 26, 2009 | 12:04 PM
Speedboy's Avatar
Default Steering Question???
Why am I still having steering trouble? I had an alignment and my steering is centered but I still am having steering issues! I have a 2010 with the 4" lift RC and dual stabilizers. Every so often the ESC light comes on and breaks. It feels like the steering is loose?? Could the dual stabilizers have anything to do with it? Please help.
Old Dec 26, 2009 | 12:06 PM
Arkansas Unlimited's Avatar
you still in this thread?
Old Dec 26, 2009 | 12:22 PM
anyway dude, I would start by checking all the points of contact, track bars, control arms and see if anything is loose. Also check your caster on the front, that will give you a nice ride called the death wobble if its bad off.
A 4" lift without new or adjustable control arms had to throw your caster way off.
Good luck
Old Dec 26, 2009 | 03:07 PM
sktdarkstar8's Avatar
ya i would agree.. retorque to make sure everything is nice and tight and if you dont have adj. control arms then it could be your caster. i experienced a similar problem so i purchased the control arms and it seems good now. i do also have adj. trac bars and i have a 3 in lift.
Old Dec 26, 2009 | 03:18 PM
nthinuf's Avatar
More info would help...
What are you doing when it comes on? (driving straight? Only after hitting a bump? Turning only one direction, but not going straight? Offramps?)
How does it handle when the light is not on? Stock-like? Flighty? Bumpsteer? (read the "Q: What is caster? how much do I need?" section of the FAQ's)
Old Dec 26, 2009 | 04:44 PM
nangulator's Avatar
X2, it sounds like something is loose or out of adjustment
Old Dec 26, 2009 | 07:13 PM
Yoda's Avatar
4" is high...
Be sure to have adj. front lower arms. You need at least 5 deg. of caster
At 4" your diff. is not centered. Buy an adj. trac bac. Get rid of the RC trac bar relocation bracket.
Old Dec 26, 2009 | 07:32 PM
sclan's Avatar
when you did the alignment, did it (the alignment shop computer) tell you the steering wheel was centered? I ask cause I had the same issue. I swore the steering wheel was centered...at least it looked it. Then I went back under the Jeep and turned the the rod a slight bit and the problem went away. What looks center and what the Jeep computer is reading may be off
Old Dec 26, 2009 | 07:34 PM
Speedboy's Avatar
Is it an easy install?
Old Dec 26, 2009 | 07:42 PM
Speedboy's Avatar
I corrected the steering I think. I used the centering mod on the AEV Procal. I is off ever so slightly. The steering almost feels loose like a slight delay. I wonder if the shocks on the stabilizers have anything to do with it??
