one more thing.
Old Dec 27, 2009 | 04:05 PM
chefralphy13's Avatar
Default one more thing.
I have seen where I need 4.5 backspacing on aftermarket wheels. I like a few Eagle Alloy wheels that have 4.46 and 4.47 backspacing. Does anyone know if this wil make a difference or not? Thanks!
Old Dec 27, 2009 | 04:09 PM
backwoodjk's Avatar
Should be fine, not much difference between them.
Old Dec 27, 2009 | 04:16 PM
wiredawg_mg's Avatar
How wide of a tire do you plan to run? Is this for an 8" wide wheel?
If you are only running a 12.50-13.50 on an 8 you will be fine
Old Dec 27, 2009 | 04:36 PM
I am planning on running a 35 12.50 17... I guess a 17x8 or 17x9 would be fine right? I would probably just go ahead and get the 9 cause it is not much more and seems the sensible thing to do!
Old Dec 27, 2009 | 04:55 PM
azrwilkinson's Avatar
Read a post a while ago and it said 35x12.50 would work great on 8 wide rim so when airing down less likely to come off the bead. :
