Lift kit ride feelings
Old Dec 8, 2006 | 02:49 AM
atvin411's Avatar
Default Lift kit ride feelings
How does the jk ride with your lift kit,Let us know I put a 4 inch on my tj and bounced all over everyone said it was better than stock mine felt so bouncy my wife didn't drive it any more which is good but I want the same ride as stock on my jk let us know.
ID:	182314   Click image for larger version
ID:	182315   Click image for larger version
ID:	184880   Click image for larger version
ID:	184881   Click image for larger version
ID:	184883   Click image for larger version
ID:	184884   Click image for larger version
Old Dec 8, 2006 | 03:52 AM
Big M's Avatar
I have a skyjacker 2.5". It definately rides stiffer than stock....which works out ok on the road for good handling but is a little rough offroad. I would suspect they geared the kit more toward the DD crowd.
Old Dec 8, 2006 | 04:09 AM
atvin411's Avatar
Default Lift
Is it the springs or spring spacers
Old Dec 8, 2006 | 06:23 AM
Big M's Avatar
All new springs and hydraulic shocks.
Name:	iphone pics 007.jpg
ID:	183595   Click image for larger version
Name:	iphone pics 012.jpg
ID:	183596   Click image for larger version
Name:	iphone pics 040.jpg
ID:	183597   Click image for larger version
Name:	iphone pics 043.jpg
ID:	183598   Click image for larger version
Name:	iphone pics 045.jpg
Old Dec 8, 2006 | 07:29 AM
wayoflife's Avatar
JK-Forum Founder
A lot of how your Jeep will ride will ultimately depend on how tall you are in relationship to the components you have (i.e. type of coils, short arms or long arms) and of course, what kind of shocks are you running. I'm always surprised at what a difference something as simple as installing a good set of monotube nitro shocks will make in the ride of a Jeep.
ID:	184098   Click image for larger version
ID:	184099   Click image for larger version
ID:	184100   Click image for larger version
ID:	184101   Click image for larger version
ID:	184103   Click image for larger version
ID:	184104   Click image for larger version
ID:	184105   Click image for larger version
Old Dec 8, 2006 | 07:55 AM
atvin411's Avatar
Default Soft ride at 3 inches
What would you recomend for the softest ride as you can tell my tj was bad you could fell a pc of bubble gum on the road and our other car is a Lexus.
ID:	262484   Click image for larger version
ID:	262485   Click image for larger version
ID:	262486   Click image for larger version
ID:	262487   Click image for larger version
Old Dec 8, 2006 | 08:08 AM
wayoflife's Avatar
JK-Forum Founder
I don't know if "softest" is exactly what you should be looking for per se but rather a shock that is responsive and one that maintains it's performance under heavy use. This will give you a comfortable ride where as a "soft shock" will give you a mushy, sea sicky ride especially on the trail.
Having said that, I'd have to say in my opinion, one of the best riding shocks you can buy without breaking the bank are Old Man Emu's. I also really like the Full Traction M-Force shocks I am running on my TJ now
ID:	184442   Click image for larger version
ID:	184444   Click image for larger version
ID:	184445   Click image for larger version
ID:	184446   Click image for larger version
Old Dec 8, 2006 | 08:32 AM
GoAnyWhere's Avatar
Part of the problem with the JK is the springs are very soft and the shocks are overdamped from the factory. Most companies are increasing spring rate which has its pros and cons. It will take a while to figure out who designed the springs well.
-J
ID:	184762   Click image for larger version
ID:	184763   Click image for larger version
ID:	184764   Click image for larger version
ID:	184765   Click image for larger version
ID:	184767   Click image for larger version
ID:	184768   Click image for larger version
ID:	184769   Click image for larger version
ID:	184770   Click image for larger version
ID:	184772   Click image for larger version
ID:	184773   Click image for larger version
ID:	184774   Click image for larger version
ID:	184775   Click image for larger version
ID:	198971   Click image for larger version
ID:	198972   Click image for larger version
ID:	198973   Click image for larger version
ID:	198974   Click image for larger version
ID:	199524   Click image for larger version
ID:	199630   Click image for larger version
Name:	2011-09-09 19.18.32.jpg
ID:	209053   Click image for larger version
Name:	2011-09-09 19.18.10.jpg
ID:	209054   Click image for larger version
Name:	2011-09-09 19.18.01.jpg
Name:	2011-09-09 19.17.46.jpg
ID:	209056   Click image for larger version
Name:	2011-09-09 19.17.34.jpg
ID:	209057   Click image for larger version
Name:	2011-09-09 19.17.19.jpg
ID:	209058   Click image for larger version
ID:	214438   Click image for larger version
ID:	214440   Click image for larger version
ID:	214441   Click image for larger version
Old Dec 8, 2006 | 08:45 AM
Phishjeep's Avatar
What's the deal with the new speed sensitive shocks? My Rubicon handles fantasticly on the street. I had a06 Sebring off the lot while they fixed the dent in my Jeeps Cowl, and I could barely stay in the lane around corners in the Sebring. Is that from mushy or soft shocks? My Saturn L200 never felt like that. I guess it was stiff like the Jeep.
Are the new shocks supposed to be stiff at high speeds and soft at low speeds for the trails?
Also, I read somewhere that there are 22 different Spring rates for the various JK models. When looking for a lift, what spring rwate should I look for. I never even see any info posted on that. Or is that in the detailed specs that you get when you buy the kit?
Old Dec 8, 2006 | 09:12 AM
GoAnyWhere's Avatar
Most of the companies will tell you, just give them a call. If you are looking for the softest ride possible, go find someone who makes springs just for a 2 dr, 2X4, non-rubicon which is the softest OE spring.
