Control Arms
Old Dec 28, 2009 | 06:01 PM
sktdarkstar8's Avatar
Default Control Arms
i am looking to get new adj. control arms, pref. Teraflex arms.. the problem is im getting them in sets of 4 and can only purchase a set now then the other set in a month or two. i got a good offer for the rear lowers and front uppers and dont wanna pass it up. would it be a waste to get them since they say that the others are used to adjust castor and pinion? its a price i cant beat but i would like to use them and not have them sit until i purchase the other set so can they be used for anything?. thanks
Old Dec 28, 2009 | 06:05 PM
ssunde1's Avatar
id save and pay a little more and get the opposite, front lower, rear upper.
Old Dec 28, 2009 | 06:22 PM
Loadbreak's Avatar
X2 Plus, you can't go wrong with TF.
Old Dec 28, 2009 | 06:44 PM
style_front's Avatar
If the price is that good than pick them up and sit on them until you can get the other 4 arms.....
Old Dec 28, 2009 | 06:52 PM
NTXJK's Avatar
Im getting TF front lowers this week and rear uppers at the end of the month do it right the first time man
Old Dec 28, 2009 | 06:58 PM
nthinuf's Avatar
TF 2.5 coil lift?
For the front, either uppers or lowers will let you set the caster. On a taller lift, the TF uppers may not adjust short enough, but at least they will get your handling to a more acceptable level.
For the rear, are you adding a new driveshaft right away? If so, you'll want the uppers. If not, these can wait.
I'd say go for it. Get the front uppers for cheap, and add the other 3 sets when you get around to it...
(probably adding TF rear uppers myself. All the TF gear is on sale for a good price for the next few days at 4wd/4wheelparts)
