power door locks vs rear tailgate
Ok a question for folks with power door locks that have the tuffy secruity enclosure.
I just installed the tuffy secruity enclosure and locked the rear with the key and noticed if I open the front door and hit the electronic switch to unlock the rear tailgate just unlocks. Is there a way to turn it off? It's kind of unsecure in a senario of a breakin. All the idiot would need to do is open the door and hit the electronic (unlock) switch.
So you locked the gate with the key only and not the key fob? If that is the case I dont believe you have activated the "security" portion of it.
I believe if you use the key fob to lock all the doors, there is no way to open the rear gate other than using the key fob. I believe it takes like 30 seconds or something but if you use the key fob the door lock switches will not unlock anything.
Somebody else may chime in to confirm this... Good luck, I love my Tuffy enclosure!
