Snatch strap opinions
Ordered a ARB "snatch strap" for off road recovery. I picked the 17,500lb version. Is this the right one? On the ARB site it says this one is for most 4x4 vehicles. Or should I have went with the 24,000 or 33,000lb one?
just looking for peoples opinion/experiences on what rating to use on snatch straps preferably the arb stuff
I understand "common sense" is always required but, the concept of a snatch strap is to have a little kinetic energy behind the pull? right?
Yes you will need to get a little momentum, that is why they say to use a tow point and not something attached to your hitch. Secondly, you need enough force that it stretches out the fibers in the strap. Don't forget to let it rest after 3 or so attempts.
http://www.4wd.com/productdetails.aspx?partID=43931
