body lift with 2.5 suspension
Old Jan 2, 2010 | 12:46 PM
chefralphy13's Avatar
Default body lift with 2.5 suspension
I have an 2.5 RC progressive suspension lift with 35 12.50 tires and 17 inch pro comp with 4.75 backspacing. I am thinking about adding a 1 inch PA body lift as well. Everything else is stock. Will I need to do anything else if I do this body lift or will it not hurt anything? Sorry if this has been asked a bunch of times but I couldn't find the answer by searching on here. Thanks.
Old Jan 2, 2010 | 01:49 PM
myklt8's Avatar
I added the 1.25 RC BL to mine...just needed that little extra to clear the 35s completely
no issues whatsoever. I do have an auto, do some more research if you have a manual
Old Jan 2, 2010 | 03:12 PM
aldaman's Avatar
Like what was mentioned earlier, if you have an auto nothing else is needed. But if you have a manual you will have to do some cutting w/the shifter boot...The 1" BL will leave a slight gap w/the rear bumper and tailgate. For me it was ok, but for others they did the bumper gap elimination mod....
