which lift 2 inch lift?????
Old Jan 15, 2010 | 09:40 AM
topdog1308's Avatar
Default which lift 2 inch lift?????
I'm ready to buy I lift kit but my only problem is I don't wanna do any mods,buy this buy that,relocate this relocate that,driveshaft this swaybar that link coil overs wheel spacers,backspacing....I'm gonna pass out..what I'm trying to say is ,I want a 2 inch lift nothing fancy ,install once and that's it ,something complet...anybody???
Old Jan 15, 2010 | 09:41 AM
MELONHED's Avatar
Teraflex leveling kit
Old Jan 15, 2010 | 09:50 AM
spinlock's Avatar
What are your expectations from the 2" lift?
Eliminating rake, clearance for larger tires, better ride, just looks ?
Old Jan 15, 2010 | 09:54 AM
topdog1308's Avatar
So is that all that I will need,,do I need new shocks,will it drive like stock and are there any modfications involved
Old Jan 15, 2010 | 10:01 AM
RevyJKU08's Avatar
What spinlock stated...also, are you going to run 33's or 35's & off-roading lots. Some 2" kits like OME coil springs will net you over 3" of lift. Are you going to be upgrading your bumpers adding a winch??? Do you want a BB or Coil Spring lift???
I have been very pleased with my 2" RE BB (coil spacer) with monoshocks that fit 33x12.5 nicely! No modifications required if you purchase the shocks but you can get shock extensions and be sure to get bumpstops.
However, I am upgrading my kit to a 2" OME HD coil spring lift to compensate for the extra weight of bumpers and winch and to fit 35's in the very near future. The stock springs...sagged about 3/4" and I still needed to add the bumpers. Reading other threads this kit will net me close to +3" of lift and thus I need to add CA's, Rear links, trac bars.
Do some research and know why you want the kit...and then look at the kits that will work for you and your JK.
Old Jan 15, 2010 | 10:06 AM
topdog1308's Avatar
I won't be doing any off roading ,love the look of a lifted jeep with 33s ,mostly looks and bigger tires...
Old Jan 15, 2010 | 10:07 AM
TEX-AG's Avatar
TF 2.5" spacer lift. Add shocks for added pleasure.
Old Jan 15, 2010 | 10:15 AM
topdog1308's Avatar
Thanks for the feedback guys butfor some reason I find it very hard to find a complete kit I don't wanna buy something and find out later down the line that I needed brackets or some type of issue,,lots of companys get you to buy a product just to tell you ..oh and you have to purchase this oh and that or it won't work
Old Jan 15, 2010 | 10:24 AM
TeraFlex's Avatar
Sponsoring Manufacturer
#1155200 TeraFlex Leveling kit.
Old Jan 15, 2010 | 11:09 AM
nthinuf's Avatar
Another vote for a leveling kit. 2" front / 1" rear
Gets rid of the rake and adds a little height for the 33's.
