Advise/Info. on the Zone or RC 4" suspension lifts?
Old Jan 17, 2010 | 10:56 AM
jcr931's Avatar
Default Advise/Info. on the Zone or RC 4" suspension lifts?
Was going to see what info or advise you guys could give on running the Zone or RC 4" suspension systems? Thanks for the help!
Old Jan 17, 2010 | 01:48 PM
jcr931's Avatar
Planman, I like the look of the height of the 4"lifts and know of several of have yet to have problems with driveshafts. I'm not going to offroad much at all and think that the driveshafts would probably be ok. I was sold at first on the TF 2.5 coil and the more if look at threads of JK's with the 4" lifts I like that look better. I know you will get around 3.1 in the front and 2.5 in the rear on the TF Coil I think and am still considering it just because after it's on you can pretty well call it done sounds like (for the most part). I'm still undecided and am not rushing (mainly cause I'm broke!) on the lift. I've got the tires and will start on the lift next and then the wheels. Still deciding on the the stock wheels and spacers or going with a whole complete set of some type of black wheels. Thanks for the reply Planman.
Old Jan 17, 2010 | 01:53 PM
mkjeep's Avatar
Always check the For Sale section, sometimes peeps get rid of their 3-4in stuff when going to a long arm or coilovers. A TeraFlex 3in will give you 4in. Also some people that have the RC or Zone or others sell theirs to go with an upgrade to something better.
Old Jan 17, 2010 | 02:44 PM
omen0786's Avatar
I have the 4" rc lift and i love the ride height with 35s probably won't add anything else except the driveshafts and lca's when needed
Old Jan 17, 2010 | 03:31 PM
jcr931's Avatar
Thanks mkjeep and omen for the response.
Old Jan 17, 2010 | 06:38 PM
jcr931's Avatar
Planman would you put in a 1" BL or some Skyjacker or TF spacers on top of the TF 2.5 Coil? I guess the BL wouldn't change the geometry of the shafts and all that like the spacers would? I just don't want a big gap between the body and the frame like most BLs do. That just looks sort of crappy to me, but a 1" BL wouldn't be quite as extreme as some 3" BLs I've put on in the past.
Old Jan 17, 2010 | 06:52 PM
jcr931's Avatar
I see where you are running the 1"MORE BL lift on yours. Was it easy to install? I see there is a thread on BL's going right now and I read it, along with the Project JK write up. So your thinking the TF 2.5 Coil and the 1" MORE BL lift would look good? Do you know anyone running this with some 35's? That should give me 4.1 in the front and 3.5 in the back with the BL?
Old Jan 17, 2010 | 07:06 PM
jcr931's Avatar
Thanks for the help planman.....the TF2.5 coil and the 1"MORE BL lift may be the look I'm shooting for!
Old Jan 18, 2010 | 05:54 AM
rcjeep's Avatar
Sponsoring Manufacturer
You might look at our New 4" X-series kit. It includes: 8 Adj arms with flex joints, 2.2 Performance shocks, HD front adj Track-bar with heims, (4) SS brakelines, rear ext. swaybar links, front discos, rear tb bracket. $1199
http://www.roughcountry.com/jeep_jk_4flex.html
60 day satisfaction guarantee or a Full Refund
Lifetime Warranty on products
3 Day shipping
Old Jan 18, 2010 | 07:59 AM
jcr931's Avatar
RCJeep, when those springs settle what kind of measurements have ya'll been getting? Also are those some of the progressive springs that some have complained about on the 2.5" lifts and/or have they fixed those problems yet? Thanks for the pics and advise!
