33" on a death wobble prone JK(opinion on dual steering stabilizer and width of 33")
I've posted on here before about my JK and the death wobble I've experienced after an off-road incident. Since then it's gotten better but it still does it occasionally on high speed bumps on the interstate. Anyways, I had some lower control arms put on and I believe that has helped out alot. Well I'm going to get some rough country dual steering stabilizers and some 33" MTZs. I know the steering stabilizer just masks the problem but I cant figure out what it is so I'm curious when I buy the 33"s they make the 12.5 width and the 11.5 width. Which width would be better to lessen the chance of the wobble because I know the bigger the tire the more chance it has to do that or so I've heard. Which me wonder if its wider it would be harder for it to do that? Any help would be greatly appreciated.
I have had Death wobble on my jeep from week 1. I just recently put 35x12.5 on her and I have driven on the highway, today as a matter of fact. The bigger and wider wheels seem to make the steering more stable. I haven't got the wobble with the wider tires yet.
I have read a lot of post on this... most refer to a loose track bar braket in the rear. Some have said loose steering components as well. Have you tried to search death wobble. It will be a lot of reading, but well worth it. Good luck
I wish it was that simple yall. I still have stock tires on it and the castor has been changed, the camber, front end aligned many times, trac bar tightned, tires balanced..it got a little better but still it isn't fixed
i have to disagree with the being an easy thing to identify.
Is it just me or is this whole DW thing just ridiculous?
I have never owned a vehicle that required such maintenance as to where if one bushing is shot or one bolt is not tightened or one hole is ovaled, the whole vehicle goes into a violent shake and the owner is left to disassemble the whole front end trying to find the one little thing that does it.
When i bought a Jeep I thought it would be tougher buit since its meant for off road but, it does not seem the case. One little thing is off and the vehicle is not even driveable, let alone off road worthy.
To me this should be the first thing you do. After trying everything I could think of and everything I had read, the problem didn't reveal itself until I removed the stabilizer. If I would have removed it first my 3 month venture into getting my death wobble resolved wouldn't have lasted 3 days.
