relocate steering shock
no luck on the search wich is normal for me. anyway, was wondering if anyone has moved the steering damper. i just installed an aftermarket one wich is almost twice as big as the stock one and now its not as hidden behind the tie rod
I installed a Black Diamond stabilizer relocation kit a few months ago. I don't know which one you installed but I assume it was relocated to the top of the centerlink, correct? I'm kinda confused by your comment that it's not hidden any longer behind the centerlink. If it's on top of the tie rod, it's not positioned to be hit by rocks or obstacles which is what you want, correct?
I believe he meant he installed an aftermarket stabilizer, that is still in the stock location. He is looking for a relocation kit that puts it above the link. I second the Jeepswag.com products. They have a bundle of the Steering stabilizer and evap canister relocator for $80, that is if you haven't already addressed the evap problem. If you just need the stabilizer relocator it is $30.
