PRESS RELEASE: Mountain Off Road Enterprises Freedom Top Storage Rack
Mountain Off Road is now manufacturing our JK Hard Top Freedom Top Storage Rack for the 2007 and newer Jeep JK Wrangler 4door. Keep your Freedom tops looking new and scratch free even while off roading with this foam lined storage box that secures your tops behind the rear seat. Store the tops upright and have the floor of your jeep to keep other items or lay the Freedom Top Rack down and strap your cooler or what ever else down using the series of holes to bungee your items secure. Fits 4 door JK’s only and is powder coated black for a durable finish.
After seeing this product at the 2009 Off Road Expo Show, this is what I had to say about it...
For more information contact Mountain Off Road Enterprises.
Call toll free (877)-Jeep-A2Z or 877-533-7229 www.mountainoffroad.com
If there were a single product that I had to give a Best in Show award to (Off Road Expo 2009), it would definitely have to be the all new M.O.R.E. Freedom Top storage unit. Functional, easy to use and available at an affordable price point, this storage unit is compact in design and will allow you to safely remove and store your Freedom Top panels safely and securely in the back of your JK and without risk of damage to them even when off roading. In the upright position, you still retain a significant amount of storage space and in the down position, it’s steel construction allows you to carry all your cargo on top of it. Loading up or removing your Freedom Tops from the storage unit can be done from the back of your JK simply by lowering the storage unit’s front panel. Or, if the back is all loaded up with gear, you can access the tops just as easily by lowering your JK’s rear seatback.
