Anyone else have JKS discos come loose?
So I installed my JKS discos a few weeks ago. Today when leaving from work I hear a loud POP BANG when I got over bumps with wheels turned. I come to a parking lot and check the whole suspension. I thought for sure I blew a U-Joint or something.
Only thing I could find was the bolt that hold the JKS sway bar link was loose. I could spin it by hand. I tightened it down and sure enough no more noise!
What I want to know is how did a nylock nut with blue loctite that I tightened the shit out of just come loose?
Anyone else have this happen?
I'm not trying to sound condescending but when you attach the bolt to the axle/sway bar link you need to put a screwdriver or hole punch through the eye of the bolt while you tighten the nut @ the same time so it doesn't spin.
65ft.lb. torqued nylock nut and lock-tite make them pretty hard to move. Mine haven't come loose @ all since I installed them.
Here's my write up if it helps
https://www.jk-forum.com/forums/show...er+disconnects
