2'bb but what tires
Old Jan 22, 2010 | 05:32 PM
natburris's Avatar
Default 2'bb but what tires
i'd like to see some pics of 2drs with 2" or2.5" bb with 32" or 33" tires. just wondering what mine will look like with a little lift if i can't afford bigger tires yet. cant justify buying new ones when mine only have 500 miles on em!
Old Jan 23, 2010 | 09:19 AM
Flagjeep's Avatar
Check out this link:https://www.jk-forum.com/forums/jk-show-tell-33/lets-see-those-33-s-2-drs-23451/
Lots of 33's here, lifts vary in height, but look through here, there are great pics.
And try using the search function. There are thousands of posts/threads/write ups/ more info than you can imagine....
Old Jan 23, 2010 | 12:39 PM
RevyJKU08's Avatar
Go with 33x12.50 tires...you won't regret it...33's look good on a 2" lift.
Old Jan 23, 2010 | 01:41 PM
natburris's Avatar
thanks guys, i was hopin to find some pics with 32's... maybe there's a good reason most of the jk's with lifts have 33's. guess i better start savin my $$$
Old Jan 23, 2010 | 07:08 PM
RevyJKU08's Avatar
Give you an idea here is my stock Duellers 32's on 2" RE lift
[IMG][/IMG]
Full Size has 33's
[IMG][/IMG]
Old Jan 24, 2010 | 03:07 AM
natburris's Avatar
[QUOTE=TripleJeep_99;1528280]Give you an idea here is my stock Duellers 32's on 2" RE lift
thanks! there isn't that much difference in the tire size, but the way the tire looks maks all the difference in the world... would u call that a "more aggressive looking tire"? still trying to learn proper jeep language
Old Jan 24, 2010 | 02:05 PM
RevyJKU08's Avatar
[QUOTE=natburris;1528580]
Yes...my 33's are much more aggressive and are a Mud-tire (Cooper STT) but also my mud tire is 2" wider than the stock which helps with the stance and look. Personally, the stock duellers look like a street tire but are called an All-terrain tire.
Old Jan 24, 2010 | 03:01 PM
BBirish's Avatar
sell your current tires get 35s
Old Jan 24, 2010 | 04:14 PM
natburris's Avatar
35's?!?!?! YIKES!
did i read somewhere that 35's aren't a very good match to the 3.21 axle ratio??? not sure... this stuff is all new to me
Old Jan 24, 2010 | 04:20 PM
Viper64's Avatar
They are not the best choice, you probably need to be in O/D off mode most of the time, and if you have stick, 5th and 6th are going to be useless with the 3.23's. If I were you go with the 33's. 35's are to large for just a 2 inch lift kit and will have rubbing and spacing issues. That and 33's in my opinion at least look great and perform great on a 2 inch lift. I have a 3inch lift that could fit 35's, but I prefer the 33's.
