new tires = bump steer
Old Jan 23, 2010 | 09:46 AM
jeepmedic's Avatar
Default new tires = bump steer
I recently upgraded to 35's from 33's. I drove on the 33's for 8K with my OME 2.5" lift with no problems and no bump steer.
Now that I have 35's I have bump steer that is getting worst. I do not have an adjustable F trac bar, and have checked all bolts for tightness and nothing is bent/broke.
I did a search and it seems the best solution is a JKS trac bar bracket ??
Any ideas
Old Jan 23, 2010 | 09:55 AM
horwitzs's Avatar
Just going to larger tires shouldn't create bump steer. It is caused by other suspension components.
Perhaps the new tires are stiffer, transmitting more shock to the suspension and making it noticeable now.
Old Jan 23, 2010 | 10:30 AM
AK4Dave's Avatar
Too much air in the new tires...???...
Old Jan 23, 2010 | 11:30 AM
jeepmedic's Avatar
I have them @ 30 PSI...and the Jeep is my daily driver.
Is it ok to go lower ?
Old Jan 23, 2010 | 12:35 PM
scarp's Avatar
I run 28 PSI in mine.
It sure improved ride quality from 30.
Old Jan 23, 2010 | 01:32 PM
AK4Dave's Avatar
Well, that's up to you. Mine's my dd too. I was told not to go under 35 but I run 30. I just try not to let the sidewalls bulge.
Old Jan 23, 2010 | 01:39 PM
curtis's Avatar
had the same problem with mine..... dropped down to 30 and it is a ton better...... although the tire shop did have 60 lbs in them when i picked it up it was more like bouncing down the road then driving!!!!!!! couldn't beleve it when i got home and checked them and it maxed out my gauge....
Old Jan 23, 2010 | 02:10 PM
interceptor_1972's Avatar
What are the specs on your 35s as compared to the 33s? If your 35s are wider than the 33s, that'll contribute some to the bump steer and going bigger will definitely make it more noticeable. Also, are you still running the stock SS or have you upgraded to a heavy duty one?
Another thing that may help would be some adjustable LCAs. Adjustable Trackbar will help recenter the axle under the jeep, but even without that, you shouldn't have bump steer
Old Jan 23, 2010 | 06:08 PM
jeepmedic's Avatar
I'm up to 315/75/16 from 285/75/16's. I still have the stock SS but am planning on getting a new HD one soon.
Old Jan 23, 2010 | 10:18 PM
Based on those specs, I'm guessing that you went from 33" tires approx. 11" wide to 35" tires approx. 12.5" wide [the wheel would probably be more recessed in the tire]. Not sure if you noticed any weight difference - I'd be tempted to say that the 35s probably weigh in heavier than the 33s. These two alone would be enough reason to feel the bump steer.
Also, did you check your "toe-in" settings? It is recommended to increase your toe-in. Here's the excerpt from WOL's writeups and the link to it:
Now, if you just installed a set of 33" tall tires, you most likely will NOT have to adjust your toe-in as the new Jeep JK Wrangler’s have been designed with a steering setup that has the drag link attached directly to the steering knuckle (as opposed to the tie rod as was the case on the older TJ model Wranglers) and your toe-in setting will not change from stock and this should be fine. However, if you’ve just install 35" tires, you may want to consider increasing your toe in to about an 1/8". Please note, past experience has shown these numbers to work well under these circumstances but are not guaranteed to be what you need.
Hope this helps
Once you have everything dialed in right, a heavy duty SS would also help
