TF leveling kit with 33's, thoughts and opinions? possable pics?
Old Jan 24, 2010 | 07:08 PM
JKmudslinger09's Avatar
Default TF leveling kit with 33's, thoughts and opinions? possable pics?
i want to beef up my jeep a bit from my little winter tires when spring comes but i cant afford the TF 2.5 kit with 35's so im gonna do a leveling kit with 33's. anybody have this? what do you all think? i know i wont get much flex without trimming but i have no major off road plans just yet.
Old Jan 24, 2010 | 07:53 PM
ifshinxs's Avatar
Here ya go.. 07 2Dr with leveling kit..
33's fit fine with no lift on stock wheels..If you get a rub on the sway bar at full lock adjust your steering stops..
Old Jan 24, 2010 | 08:23 PM
that looks awesome! thanks. i was looking at trying to throw a 305/75/16 under there. i think its like... 34.1" give or take a bit. probably a little big...
Old Jan 24, 2010 | 09:08 PM
spinlock's Avatar
If you need more examples there are a lot of combinations of lift/tires in the 33" Tire Thread in the Show Off Section of the Show and Tell subforum.
Old Jan 25, 2010 | 07:17 AM
ifshinxs's Avatar
To be honest I think those 305's will fit with the leveling kit..The kit gives you
2" up front.. If those 305's are less than 11" wide I think your good..Again I know you'll have to adjust yor steering stops with a couple of 5/16th washers on each side. Its that or go aftermarket wheels with the correct offset..Or spacers..
I'm real happy with the leveling kit running 33's no rubbing on or off road..
Old Jan 25, 2010 | 08:51 AM
SAUnlimited's Avatar
I was (for a short time) running 295-70-17 with 1.5" wheel spacers and a 3/4" front leveling kit. The attached pic was without wheel spacers. Without the wheel spacers the tires would rub at full turn.
Old Jan 26, 2010 | 07:50 PM
looks great. my buddy talked me into it today. 33's and a leveling kit it is! maybe a 2.5" lift a little later in the summer and a bump to 35's next year
