What is the largest lift for 2dr?
What is the largest lift anyone is running out there on the 2dr?
Please post up some pics and list out all modifications you had to do.
I'm running a 4" tuff country and plan on adding 1" MORE body spacer, xenon flats, and possibly popping in some 1-2" poly Daystar discs so that I can clear 40's.
I'm worried how far a 40" tire would be stuffed @ full flex w/out more of a lift than what I would consider my small lift. My current 35's get ~1" away from my stock fenders when I'm at full flex in the front.
Search!!!!
Year/Make/Model: 2007 Jeep JK Wrangler
Engine: Mopar 392 Hemi V-8
Transmission: Mopar 5-45RFE
Transfer case/low range ratio: Atlas/5.0:1
Front end: Currie RockJock high-pinion 60
Rear end: Currie RockJock high-pinion 60
Ring and Pinion: 5.38:1
Suspension: Modified 3.5-inch Currie Enterprises 5-link front/4-link rear
Tires: 14/42-17LT Interco Irok bias ply
Wheels/Backspacing: 17x8.5 Pro Comp 1028 alloy/4.75 inches
in the "show your boggers" thread, there is a monster JK 2 door on 40" boggers.
https://www.jk-forum.com/forums/show...1&postcount=23
TeraFlex SEMA JK
2.5" TeraFlex Long Arm kit with SpeedBumps and ELKA shocks sitting in 40's. This is Lower 40's bigger badder brother.
http://www.teraflex.biz/frontpage/te...-2009-sema-jk/
Build thread.
https://www.jk-forum.com/forums/show...highlight=SEMA
Build thread.
TeraFlex SEMA JK
Build thread.
Build thread.
