Part number for ARB Locker on X Unlimited D 44 rear
Old Jan 26, 2010 | 07:10 PM
phljeeper's Avatar
Default Part number for ARB Locker on X Unlimited D 44 rear
What part number should I have installed on the Dana 44 rear in my X? I just looked through my paperwork from my 4.88 Yukon regear and locker install and it looks like they installed a RD117 for gearing 3.73 and down. I have had a few issues with the regear installation including a seal on my drivers rear wheel and am now looking through everything in detail to see if I have any other issues.
Old Jan 26, 2010 | 07:14 PM
km2jk's Avatar
I was just looking into this for my TJ's soon to be JK axles. The JK rear axle uses the same locker no matter what RP ratio you use. The gears are different thickness instead of using a different carrier. You can look it up on ARB's website. There is a section on the JK axles specifically
Old Jan 26, 2010 | 07:19 PM
Northridge4x4's Avatar
Sponsoring Vendor
RD117 is the correct locker
Old Jan 26, 2010 | 07:21 PM
phljeeper's Avatar
That was what I saw on their website as well, but resellers are listing two part numbers based on the gear ratio. I assume you are right, I am just paranoid after the issues I have encountered with the re-gear.
Old Jan 26, 2010 | 07:22 PM
phljeeper's Avatar
Awesome, thanks.
