2 inch coil spring lift?
I am striking out looking for a "somewhat complete" 2 inch spring lift for my 08 2 door JK automatic. I only want to run 33's and want to avoid replacing drive shafts. Everyone out there with a 2" lift is a spacer budget boost. OME makes a 2" lift but on my stock 2 door will yeild me about 3" of lift. Rusty's makes a 2" coil lift but it is just springs and shocks and nothing else (no sway bars, trac bar relocation bracket, etc). Basically I am just looking for something like the 2.5" Teraflex budget boost except with 2" springs instead of 2.5" pucks.
Why dont you just get the RC 2.5 coil lift. It is not high enough to worry about drive shaft issues and you will be able to fit 33's fine. I just bought there 3.25 kit after months of research.
Same as Rusty's just $10 cheaper. I am looking for something a little more complete with at least rear sway bars and a trackbar bracket. The Teraflex 2.5" budget boost would be perfect but I want to get rid of the soft factory springs.
See what you think of the JKS ACOS system. It's adjustable... that's what sold me.. and some really satisfied friends that have it. I'm putting it on my JK next week. Seems like a straightforward way to gain the room for larger tires without getting into too much adjusting... Just an idea for you. good luck!
