lightest weight 33" tires?
I'm looking to go up one size to a 33" tall tire. I'll be running 17" wheels.
I'm wondering who makes the lightest 33s. I know some Toyos and Mud Grapplers are heavy. Trying to get something light to keep the gas mileage close to the same. I dont't intend to re-gear.
Anyone have any real numbers?
FYI - Going one size up to 33's will probably only get you .5" of diameter... Most 33's are more like 32's. My 285/75/16's actually only measure 31.25" at 35psi when mounted... Of course it varies by manufacturer, but unless you just want a different tread pattern, might as well save your money.
Jay
Do a search for the tire size you want on tirerack.com and take a look at the list. They post weights on almost all the tires. The Duratrac came in lower than most if I remember correctly but I was looking at 35's.
the 285/75r/16 toyos that i run made my gas mileage suck. love the tires but if you use them you will want to regear. my mileage is a solid 14 on the interstate at 70-75 mph but what frustrates me the most is the performance. any slight rise in the highway and i loose 5 mph before the tranny will downshift to get my speed back to cruise setting. so good luck on that " not going to regear "
Thanks guys for suggesting tirerack. My stock tires will be worn out in a few months. Only looking for an extra inch in height at the most. Just didn't want to add the extra rotating mass. I'm just trying to research in advance.
CHeers
To my surprise, the Goodyear Kevlar MT/R outweighed the BFG MT KM by 4 poundes each, same sized tires 255/80R17
http://www.tirerack.com/tires/Compar....jsp:thinking:
Guess I'm going with KM2's at 33 inches when the stockers wear out, that's only a 3# increase per wheel. I'll still get a procal to keep things close to right.
I too am interested in keeping this Rubiwagon as near stock until I find the $ to do it right. I think right now my Jeep has plenty of pep stock. More protection underneath, a lightweight front bumper and winch with 33 BFG
KM2's should suit me nicely.
