With 2inch lift, do u suggest front discos for articulation?
Never used discos before, but wondering if it is something I should replace with Quik Discos.
Only have 2inch Skyjacker coil spacer lift with Nitro shocks.
Or is this something that goes along with replacing flex arms and such?
Gracias
Gracias
You definetly want to disconnect, you can get decent flex from the stock coils with a BB. With my 2" BB and 33's I do rub a little on the flare at full flex.
I have the electric disconnect so that is why the swaybar link is still connected in the pic below.
Disconnecting greatly enhances your axle articulation. You will be amazed how much it helps. Just disconnect your sway bar links and you will see. TYry it out first that way and you will then want to spend the money on some quick discos.
Lots of options out there, but hard to beat the JKS Quicker Disco's
http://project-jk.com/jeep-jk-write-...s-installation
[QUOTE=Rock (me) 4 low;1536370]Never used discos before, but wondering if it is something I should replace with Quik Discos.
Thanks to all who advised. I really appreciate the help with this question. NOW WHO WANTS TO VOLUNTEER TO BUY ME SOME JKS QUICK DISCOS ??? J/K, I'll get em soon, still waiting for parts to arrive from 4wheel parts, its been 3 weeks, apparently they are slow..
