Teraflex 2.5 coil lift w/shocks installed:)
Finally got it and lower front control arms installed no issues, except one. The front is approx. 1 inch higher than the back, is that normal? Otherwise it's awesome.
before
after
before
after
I have other(crappier) pics off the ground to the flares and before the lift they were approx. 36 1/2 from the ground. Now they are 39 1/2 in back and 40 1/2 in front, about an inch higher. Did anyone else see this?
Wow, looks great!!!!.
That's the one I want for mine, and, as I've been asking the same I may give you the answer for that 1" more in the front: It's because Teraflex directly creates their kits thinking that people will fit a bumber and winch, which gives much more weight than original bumper.
Some other brands don't make this prevition and when you add the bumper and winch the car goes down in the front and you must add coil spacers.
If you add the bumper and winch, you'll see how that 1" will go down and get perfectly leveled.
Since you got the kit with shocks, you also got the 1/2" coil spring retainer for the rear, right? Did you reinstall the factory rubber isolator on the TF retainer? Or did you use the TF retainer alone?
Looks good!
