pics of JK w 255/85-16 anywhere?
Anyone running these tires, I see limited availability from tire mfgs. I'm currently on 235/85-16s on steels. A little more diameter & width would be good but I don't want the full on huge tire deal, still want my 7" wheels too.
Thanks.
Thanks.
There are a lot of threads and pictures with this size. Use the "Search" function and then click away at the results. Also, if you do a search on Google, you will find who makes that size, especially if you check out the "Shopping" button. Good luck!
Here is a start...... https://www.jk-forum.com/forums/modified-jk-tech-2/255-85-16-285-75-16-a-93612/
