Does a shorter than stock ADJ trackbar exist?
So u can see the sig, got about 2 1/2+ inches of lift and was doin good with the JKS adj front tb, but my tb holes got wallowed out so i went with the Currie TB relocation bracket, well now my axle is pushed to far to the starboard side haha (passenger side) and I took the JKS off and made it as short as possible, which is the same length as stock. well i need to go shorter than stock.
So, is there one out there, or have i just made a big mess out of my front end??
For what its worth I've gone back to the stock trackbar too. I have a 4" long arm lift that had the track bar set as short as possible. Changing back to stock required me to turn the drag link coupling <1/4 turn to center the steering wheel - there's really not much difference between the two trackbars for my lift.
I've since fixed the aftermarket trackbar bushing but haven't felt the need to re-install the trackbar.
yea i took of the jam nut and cranked it down into the inside tube. theres no jam nut on there right now, i know thats probably bad, but it felt pretty solid. just until i can find a thinner jam nut.
on another note, is it bad that my drank link and track bar are not parallel to each other??
