315/70r/17 on stock rim?
4wheelparts.com/Tires/Goodyear-Wrangler-DuraTrac.aspx?t_c=13&t_s=163&t_pt=100892&t_pl=1002 65&t_pn=GDY312031142[/url]
anyone running these on a stock rim without a spacer?
They are 34.4 inches.
Last edited by mkjeep; Feb 2, 2010 at 08:03 PM. Reason: no non sponsor clicky please
Yes.
I ran bfg allterrains in that size with spacers for about 5 months and just today actually removed the spacers and they just fit. A couple things to note is that I am not running a rear swaybar which could affect clearance, not sure. I do have slight contact with the front swaybar and front lower control arms. Only at full lock though. I like the look of the tires under the fenders. I am happy without the spacer.
I measured my BFG allterrains of the same size on the rim and they are actually 33.5-34".
Yes.
Have you noticed any changes in road manners? You should.
There is a noticeable difference but nothing I don't feel I can't handle (that includes evasive maneuvers which I have had to make). I am able to totally lift my drivers side tire about a foot off the ground when making a u-turn and accelerating out of it at just the right time (don't ask me how i know!!!) I have been running without one for about 8-9 months.
Thanks for the replies.
I want to go to 35's, but I actually like the rims on my rubi.
and I do not want to use spacers.
I was gonna go with 33" KM2's, but the duratracs are a touch cheaper and they are 35's.
jeepnxj3 did you have to trim the pinch seam?
35x12.5 on the stock rims. Why not go with spacers? No different than a wheel with different offset, plus i think the wider stance looks more aggressive. Handling is a little looser, but I'm not complaining.
Here's some more info, I don't feel like retyping...
https://www.jk-forum.com/forums/modified-jk-tech-2/stock-moab-wheels-35s-117479/
I have not trimmed it. I shortened my rock rails but probably didnt need to.
