Another JK build I want to share (34's with 2")
Old Feb 3, 2010 | 02:59 PM
rhinocat's Avatar
Default Another JK build I want to share (34's with 2")
Just wanted to share my build details. I will post pictures before and after. The build will be a 2007 4dr JK with 4.10 gears (stock 4.10) here is a list of items I have ordered today:
2.5" ProComp lift
3/4" front leveling spacer (for 9000lb warn Power-Plant)
ProComp steering stabilizer
ProComp 16x8 7089 wheels
Nitto Terra Grappler 295/75/16
Spare tire spacer and brake light lift
I know this is a pretty standard lift and tire combo, but I thought I would share anyway.
The only thing I need help on is a programer for the spedometer and gearing, any suggestions? (I will also do a search).
Thanks
Old Feb 3, 2010 | 03:10 PM
nthinuf's Avatar
Just a heads up, those tire are short...
32" actual height on my 4door
Old Feb 3, 2010 | 03:44 PM
jackson2010jk's Avatar
use the AEV Procal for a programmer. Its cheap and does so many other things that it pays for itself.
Andrew
Old Feb 3, 2010 | 04:42 PM
rhinocat's Avatar
Default What rim width do you have?
nthinuf,
What rim are you running? I am going with 8" and I am being told the 295/75 will be 33.5" tall.
Old Feb 3, 2010 | 04:43 PM
rhinocat's Avatar
Default I will check it out.
Andrew
Andrew, thanks for the suggestion I will definitely check that one out.
Old Feb 3, 2010 | 04:45 PM
CDN-JK's Avatar
Originally Posted by rhinocat
nthinuf,
Yeah, 285/75 R16 is just over 33", so a 295 with same ratio will be closer to 33.3 or 33.4.
You areeeeeee correcttttt
Old Feb 3, 2010 | 04:53 PM
stefel22's Avatar
Just a quick FYI My 295/70/17s Nittos were supposed to measure 33.3, when measured for my tire recal for my superchip they actually measured 32 1/4 from floor to the top of the tire
Old Feb 3, 2010 | 04:54 PM
DCJEEP's Avatar
Weird I did a search and got this
Stock Tire - 295/75R16 >Search Tires
Section Width: 11.61 in 295 mm
Rim Diameter: 16 in 406.4 mm
Rim Width Range: 7.5 - 9.5 in
Overall Diameter: 33.42 in 848.86 mm
Sidewall Height: 8.71 in 221.23 mm
Radius: 16.71 in 424.43 mm
Circumference: 104.9 in 2664.4 mm
Revs per Mile: 622.3
nthinuf's Avatar
You guys are looking at the mfg's specs. Very few tires are the size they state after mounting and with the weight of the vehicle on them.
My rims are 16x8.5, running around 30psi.
(measured with a yardstick, and verified with a procal and gps...)
My new Maxxis Bighorns are spec'd at 34.6, the actual height on my JK is 33.6.
I hear the new MTR/K's are true sizes, but I haven't seen any to measure
Old Feb 3, 2010 | 04:57 PM
CruserBruiser's Avatar
I would suggest the Superchips Flashpaq. It does everything the procal does plus extra horsepower and torque gains. The gains are not astronomical like with diesel tuners but they are a noticeable and help the JK in every way.
