Bedliner problem?
When you bedline your grill with a rattle can, does it come out clean, or can you see uneven spots, and imperfections? i feel like since it sprays so thick, it would be hard to mess it up, you know??
Here are a few tips.....
Rough up surface with sandpaper.
Make sure its warm out.
Dont spray in high humidity. It will lighten the finish, almost looks as if its chaulking. It does cover up if it happens, just have to use more.
Like the previous post spray many light coats.
There were 2 brands that I found. Duplicolor and Rustoleum has a product. I like the duplicolor best, the rustoleum spray was way 2 heavy (sprayed to much)
