daystar 1 3/4 leveling kit instal
Old Feb 4, 2010 | 08:20 AM
tigers34's Avatar
Default daystar 1 3/4 leveling kit instal
I'm installing the daystar 1 3/4 comfort ride leveling kit this weekend. The instructions look fairly straight forward. Is there anything that I should watch out for or know that is missing in the instructions?
Thanks
Old Feb 4, 2010 | 08:42 AM
wayoflife's Avatar
JK-Forum Founder
yeah, make sure to tighten your track bar bolts to 125-130 ft lbs of torque when you are done.
Old Feb 4, 2010 | 08:43 AM
Machine154's Avatar
If you have recent stock, it won't have front bumpstops, so be careful if you were planning to upsize tires.
Old Feb 4, 2010 | 08:56 AM
tigers34's Avatar
I have not checked the box for all of the parts - but why did they quit including the bumpstops? I was planning on going from 255x75x17 to 285x70x17.
Old Feb 4, 2010 | 09:46 AM
D_Acord's Avatar
A coil spring compressor would have helped me a great deal. What is the need for the rear trackbar relocation braket? It is only adjusting it a inch.
Old Feb 4, 2010 | 10:26 AM
jason0341's Avatar
Why would you have to loosen the track bar bolts at all with this lift being it is under 2"? Is there a set lift number (inches) before having to loosen and remove trac bars? I understand if it using a new trac bar bracket to relocate too.
Old Feb 5, 2010 | 05:32 AM
Machine154's Avatar
Cost cutting. I'm not sure if your leveling kit is the same as what I ordered (I was getting 1.75 spacers on all 4's. The kits I saw pictured on many sites at the time showed the bumpstops and so did the small 'ad' on their own instruction sheet! I had already scheduled my weekend for it and paid extra to get stocked inventory and shipped quickly, so I ended up putting it on without. I really wish I had them on - it would have prevented some of my rubbing on my 33x13.5's. You may or may not rub without bumpstops if you are offroad, disconnected and hard-flexed. If I had planned better and could do it again, I would put in a set of 1" metal disc bumpstops that mount on the lower spring perch.
Old Feb 8, 2010 | 07:27 AM
tigers34's Avatar
Leveling kit installed yesterday. Everything went well and it looks good. Next up new tires. I plan on going with Nitto Terra Grapplers 285x70x17.
