TF 2.5" coil lift with shocks, .5" sag...
Old Feb 7, 2010 | 12:24 PM
4x4fn's Avatar
Default TF 2.5" coil lift with shocks, .5" sag...
TF 2.5" coil lift with TF 9550 shocks, been on my jeep for 4 days now and noticed that the passanger side seem to be abit lower then the drivers side, about a .5". Also the shop that installed the lift reinstalled the stock bumpstop on top of the TF bumpstop. Is this correct. Doesnt look right to me. Anyway can someone chime in and help me out....
ID:	36742   Click image for larger version
ID:	36743   Click image for larger version
ID:	36744   Click image for larger version
Old Feb 7, 2010 | 12:28 PM
4x4fn's Avatar
Here is a side shot of the left and right of my jeep. YOu can see the difference in wheel well space from the driver side to the passenger side.
ID:	36746   Click image for larger version
ID:	36747   Click image for larger version
ID:	36748   Click image for larger version
Old Feb 7, 2010 | 12:57 PM
mkjeep's Avatar
You shouldn't have a block on the front axle perch, you use those with a 4in kit. You'll have to drop the front axle and pull the springs to get them out.
stockrubi's Avatar
Echo was right. you have an unneeded bumpstop connected to your axle.
Old Feb 7, 2010 | 01:20 PM
JeepNDad's Avatar
x3 Extra block has gotta go
Old Feb 7, 2010 | 01:52 PM
aldaman's Avatar
Aside from that extra bumpstop..From this view, it seems like the TF bumpstop is not sitting flush seems to be angled a bit...
Old Feb 7, 2010 | 02:15 PM
_J__C_'s Avatar
I wasn't sure how to copy OP's first pic so I used this, but in the first pic it looks like the weight of the jeep is resting on the bumpstop.
Old Feb 7, 2010 | 02:52 PM
JamesJKB's Avatar
I've Read some post about people using something to wedge the tf bumpstop into place, could the shop just not finished seating the bumpstop and left that thing in there?
Old Feb 7, 2010 | 02:54 PM
burnout88's Avatar
Wow!! You paid for that work? Scary! I can not believe the shop that did that actually thought it was right and returned the jeep to you like that. Tells you they did not know even the basics of installing a lift.
Old Feb 7, 2010 | 03:50 PM
4x4fn's Avatar
So what do I need to do to make it right...
