Wheel Spacers or Not???
Old Feb 10, 2010 | 12:45 PM
RevyJKU08's Avatar
Default Wheel Spacers or Not???
Well, I searched and searched and couldn't find an answer to the lift compentents I will be using.
I am getting OME HD coil springs add, Northridge rear swaybar links and JKS front and rear trac bars and Teraflex lower CA's.
....So my question
Will I NEED wheel spacers running my Stock Sahara rims and Tires (32x10.5) with these lift components??? Reason asking is I run my stock rims and tires in the winter months.... will I have rubbing issues on the rear swaybar links???
Thanks,
Mike
Old Feb 10, 2010 | 12:55 PM
renpia's Avatar
With stock tires, you won't need them. But when it's time to go taller and wider, you will want them while running the stock rims to prevent rubbing. I put them on mine while I wait for funds for 35's.
Old Feb 10, 2010 | 08:09 PM
RevyJKU08's Avatar
Good to hear I was not sure if I could...thought I would have issues with the Rear Swaybar links that I would need to add from Northridge. I more than likely will not go with a wider tire on my stock rims as I only run them in the winter months. I have my good set of wheels with the proper BS for wider and bigger tires.
