Rock Krawler Tie Rod.....what ends?
I bought the Rock Krawler Tie Rod and picked up a pair of Moog ES194R tie rod ends from Rock Auto......
Got everything in today and went to go put it together.....the tie rod ends don't fit!!! They are too small in diameter to screw into the tie rod.....
What is the Moog equivalent of the stock tie rod on the drag link at the pitman arm?
I don't want to use the stock replacements as they are expensive and not greaseable!!
Thanks
Thanks
You got the wrong ends. You need Part#: 52060049-AE it is the drag link rod end. RK changed this a while ago. You can get them from moparparts america for $90 shipped.
WOL write up.
http://project-jk.com/jeep-jk-write-...ation-write-up
WOL write up.
