which 6" lift should i go with?
been lookin at bds, teraflex, and rough country. which is best and what should i go with? aslo lookin to put 37" tires and still be able to be a daily driver, but also be able to climb mountains, haha. suggestions?
besides climbing mountains and being a daily driver....what is your budget? if you dont put it on yourself you will also have installation costs on top of lift costs. if you are putting it on yourself how capable are you? some of the lifts require cutting and welding. I would also throw in that in the lists of lifts you provided you get what you pay for. The cheaper lift is exaclty that...the more expensive lifts are more complete.
I am in the process of putting on a 4" long arm BDS . Good price and warranty. You will probably need drive shafts too. The other lifts are the choice of more JK owners then BDS but BDS does have a history with the TJ,YJ,CJ and trucks . It is all personal choice. Buy the BDS and the savings will pay for the drive shafts
First off, how big of tires do you want to run? I would suggest you take a close look at what companies use for bushings. TeraFlex uses Clevite bushings for factory like ride and to cut down road vibration and noise. Some companies use a poly bushings, these tend to limit flex due to how rigid they are and will split/fail over time.
Co-workers sitting on 40's with a 6" TeraFlex LA kit with 1" coil spacers.
Full traction has a 6" long arm lift. Four link with track bars front and rear. I am very happy with both on and off road performance! Check their site; the kit is not shown because it is the same as their 4" LA kit with different springs. Eddie was running it until he changed out the springs for coil overs. He still has the arms etc.
Catch this YouTube vid of me doing a walk-around of my Jeep while at SEMA....youtube.com/watch?v=viAFFDgGzR4 to see live action what the TeraFlex 6" kit looks like.
I'm running a 6" TeraFlex Elite LCG long arm suspension system along with 41" tires. There's a few companies out there that offer 6" 'lifts' but the brands offering 6" 'suspension systems' are few and far between. That's why I chose TeraFlex. Their 6" system includes, out of the box, everything you need to get your Jeep lifted to that height the RIGHT way except the gears and drive shafts (which they sell too). This means shocks, coils, adjustable control arms (not fixed length), stainless extended DOT brake lines, hi-steer brackets, new heavy duty front and rear trackbars, drag link flip kit, rear trackbar bracket and swaybar links plus all the hardware. The other guys make you piece your kit together and often some things don't work with one another and you end up having to scrap it all to start over again.
The TeraFlex 4" long arm kit is a good starting point that will net you at least 5" in true lift and if you ever want to upgrade to the 6" system - you just get new coils and maybe a few inexpensive add-ons.
I'd go with 4.5 if you want to run 37's
Lots of work and expense in a 6"
Plus I rather have a full functional suspension with the lowest center of gravity as possible. Roll overs are a real buzz kill
In fact, I'm saving money 'cuz I wanna change my lift for the Teraflex
