Further opening rear doors
Old Mar 12, 2010 | 09:32 PM
motskater's Avatar
From: Los Angeles, California, United States, United States
Default Further opening rear doors
Anyone know of a mod? everyone always complains about how there isnt enough room to get out.
Old Mar 12, 2010 | 09:39 PM
jduda's Avatar
Undo the strap that stops the door. You just have to be careful because it will open all the way into the front door. Or if you wanted you could make the strap longer somehow so that it will open more but won't swing around and hit the front door.
Old Mar 12, 2010 | 11:17 PM
spinlock's Avatar
Someone used to make some adjustable ones for the TJ.
I just used an adjustable strap instead or even better just remove the doors.
Old Mar 14, 2010 | 01:16 PM
pastorsteve's Avatar
I would tell them to drive themselves. I have a Wrangler (2 dr) without a rear seat because Wrangler's are for one-two people. Family cars have nice large rear seats and 4 doors.
Old Mar 14, 2010 | 04:06 PM
jduda's Avatar
Well said. That really helps this person out. Thanks for the input Pastor..... Really... Good Job.
Old Mar 14, 2010 | 04:22 PM
NormalJeep's Avatar
I've got a four door and a family. It's a reasonable question, he was looking for help, not asking to be judged.
I like the idea of the longer strap, I may have to look into making something like that.
Old Mar 14, 2010 | 05:08 PM
Nobody judged anyone - you whiner. Anyone given a ride should be grateful they were driven around. Anyone complaining about getting into or out of a Wrangler A) has never been in a Wrangler, and B) shouldn't be in a Wrangler a second time. If you are unsure how tight the access and egress is to/from the back doors of an Unlimited then you didn't do your homework prior to buying it.
Old Mar 14, 2010 | 05:15 PM
Cedo Nulli's Avatar
If you can find some 1" nylon webbing (like a nylon tube strap or rope guard for rappeling) and cut it to length, loop it back over itself and sew it up good, they make great door straps. Made some like this for my buddy's TJ when we replaced them all.
Old Mar 14, 2010 | 06:07 PM
JungleJeep's Avatar
I would be careful extending the straps. I have a feeling that if you go beyond 90 degrees, it will open 180 degrees and his the front door.
Old Mar 14, 2010 | 06:13 PM
NormalJeep's Avatar
I have a feeling people don't ride with you for more reasons than your lack of a backseat.
Good day
