Question about tires
Old Mar 13, 2010 | 06:02 AM
FT_Exit5's Avatar
Default Question about tires
was just wondering if a 285/75r16 would rub on the wheel well of a JK with stock 16" wheels?
Old Mar 13, 2010 | 08:00 AM
azrwilkinson's Avatar
try doing a search for this. There is plenty of threads on this. good luck
Old Mar 13, 2010 | 10:07 AM
DirtyJK's Avatar
you can do a search but the more you search the more you are gonna be scratching your head. some will say YES and some will say NO. I would say give it a try and be prepared to buy spacers in case it doesn't work. that is what i am doing with my new 305/70 R16, I am getting rims with 5" backspacing knowing I may need to get spacers!
Old Mar 13, 2010 | 10:20 AM
Stuka's Avatar
I think they will with the stock wheels. They have a lot of backspacing and really suck the tires in. I ran 265/75R16's on the stock steel wheels and they came close to rubbing, but never did. I think a 285 would though.
Although, a 285 is pretty wide for the stock 6.5" wide wheels. I think if you go with 285's, you should look for a wider wheel with less back spacing.
Old Mar 13, 2010 | 10:29 AM
BikinCO's Avatar
Default 255's?
Have you thought about 255/85 16's? Stock width but a little over 34" tall.
