Everyones 2 Cents on Skid Plates and Tires
Old Mar 14, 2010 | 06:05 AM
PagosaGlen's Avatar
Default Everyones 2 Cents on Skid Plates and Tires
Looking for input on upcoming upgrades.
I have a 2010 Rubicon 4 door with 4 inch lift.
Which skid plates have you found are needed, wish you had had, or damage that occurred because you didnt have? I currently have a Evap canister skid plate installed so far.
I am currently running the stock BFGoodrich tires. Looking to go bigger. Majority of driving is highway, so I would like something that rides well on pavement, but when running on the trails I would like something that works well. Should I stick with BFGoodrich Mud Terrain or is there something else that works better?
Old Mar 14, 2010 | 06:11 AM
HappyCurmudgeon's Avatar
Eternal ***erator
I would say protect your oil pan, and your evap, the rest of the skids IMO are optional. The ones that come with it do a pretty good job. A lot of people dont add anything, and have very few problems.
It depends a lot on your intentions...
I have a full set of RockHard skids under mine, they are great but they weigh a LOT and for where i wheel now, i dont really need all that belly armor, stock would be fine as long as the pan was protected.
Just my 2C.
Old Mar 14, 2010 | 06:19 AM
CJ7nvrstk's Avatar
Vet Army
What Happy said.
As for tires, you need to get at least some 35s under there. Will help immensly.
Old Mar 14, 2010 | 06:32 AM
RubiDude's Avatar
Question for all the people more knowledgeable than I...would a busted oil pan from trail damage be covered under warranty? I ripped my evap can off on the trails and brought it back to the dealer and he replaced under warranty. Just wondering...
Old Mar 14, 2010 | 06:33 AM
RubiDude's Avatar
Can you post a pic of your JK with the lift and stock tires? Am very intrigued.
Old Mar 14, 2010 | 06:34 AM
Eternal ***erator
I doubt it. It isnt Jeeps fault if you squash your pan, but that is up to your dealer. They may or may not allow it.
Old Mar 14, 2010 | 06:50 AM
PagosaGlen's Avatar
Default 2 Cents
Oil Pan, very good. I was thinking that should be the next item. Looking at Rancho. Any thoughts?
CJ7nvrstk... I was hoping that I could go up to 35's and still have a somewhat road comfortable drive. Any problems with running 35's on a everyday basis? Do I need to add anything to my suspension?
RubiDude... here is my jeep as it stands....
Old Mar 14, 2010 | 06:52 AM
natburris's Avatar
rubi dude, let us know if that gets covered or not! i just repaired mine, and it was a job! i'm a little mechanically challenged. i figured there was no way that is warranty work, so i just bit the bullet. let us know!
Old Mar 14, 2010 | 06:53 AM
redrockin7's Avatar
Oil pan skid.
I love my 35" BFG KM2s. I drive mostly highway and wheel maybe 1-2 times a month... Work well both places.
If you are going to 35s, probably want to consider re-gearing; best thing I've done to date to help driveability.
Old Mar 14, 2010 | 06:54 AM
Eternal ***erator
If i ever pull off my rockhard skids to save weight, this is going on immediately: Benchmark Designs 3.8L Rockcrawler Oil Pan Installation Write-Up
