Spacer ? on 2.5 TF Coil Lift
Have decided to go with this lift and 35" tires on my new 4dr...will I need to buy the 3/4" front spacers to level it out or will the lift do that for me? Any pics of this setup would be appreciated too. TIA.
Shouldn't need a spacer, but I can always add it later if u decide u do need it, but I'd recommend just going at it without one first, then if u add enough heavy stuff up front u MAY want to add a 3/4" up there, but I don't think ull need it with the TF coils. There are PLENTY of ppl with pics on here with that exact set up, check out the show off threads in the show and tell section, good choice on lift by the way
I just put on my TF 2.5" coil and to me it looks a titch low in the rear. Maybe because of the 35" spare? Not sure. I guess I'm just gonna have to get a new front bumper to even it out!
Joe from Teraflex can correct me if I'm wrong but the TF 2.5 Coil gives you 3.1 in the front and 2.5 in the back. Here's mine with the TF2.5 Coil w/TF shocks and a PA 1" Body Lift. Good luck on the project!
