Time to go shopping! Need some help.
Time to spend some $ on my JK. Would like to finalize my grocery list so here goes.
The Ride: 2010 JK Unlimited Rubicon - Automatic w/ Hard Top
The plan:
As for the lift, based on my plan and research done on the forum I have chosen to go with either the TeraFlex 2.5 Coil w/ Shocks or TeraFlex 3" Coil w/ Shocks.
My goal is to achieve a well mannered and smooth ride as compared to stock, if such a thing is possible.
What other items should I purchase and install at the same time to achieve my goal without going overboard?
Front upper / lower arms?
Rear upper / lower?
Front Trackbar?
Rear Adjustable Track bar?
Steering Stabilzer Upgrade?
PlanMan - If your out there I would really appreciate your knowledge!
Thanks!
The plan:
- Trek Top
- Lift
- 35's
- Bumpers w/Tire Carrier & Winch (soon, but not right now)
Rear upper / lower?
Front Trackbar?
Thanks!
The plan:
Rear upper / lower?
Front Trackbar?
Thanks!
The plan:
- Trek Top
- Lift
- 35's
Rear upper / lower?
Front Trackbar?
Thanks!
all that stuff listed above, minus the SS. keep your stocker until you bash it in wheelin.
I know TF has a 3" with full control arm kit however, it doubles my price. Are all the arms truly needed all at once?
im not so sure on a 4dr, but i think you will need the CA's with a 3". you may not need a rear track arm, though. hopefully someone with this lift and a 4dr will chime in.
